Post by madmonte04 on Feb 27, 2022 11:43:57 GMT -6
So I've got a 2008 jonway 250 and I'm wondering if there is any way to upgrade the headlights, seeing as they use pretty dim bulbs. In don't know if anyone has tried doing LED for them, or if there is a different way to upgrade. Thanks in advance
Post by madmonte04 on Feb 11, 2022 16:58:45 GMT -6
Have you checked compression? If you are getting fuel and spark the only thing missing is compression.
Jonway yy250t
by: madmonte04 - Nov 2, 2021 18:48:30 GMT -6
via mobile
Post by madmonte04 on Nov 2, 2021 18:48:30 GMT -6
I recently became the owner of a 2008 jonway yy250t with 1000 miles on it. Generally taken care of, it was a 2 owner scooter.. First guy literally put 50 miles on it and traded it in. The second owner bought it at 78 years old and never rode it. His nephew put the miles on it last year, but it mostly just sat. Anything major I should be aware of that might be an issue from sitting that long? It runs and rides mostly fine, I do need to adjust the idle as it idles at 1300 rpm so wants to bog down. I fixed the front brakes, they thought it simply needed bled but the handle wasn't functioning properly already replaced.
I will be changing the oil and replacing the spark plug, though said they were both new I'm rather untrusting there.
