Post by klborschel on Mar 15, 2022 22:20:58 GMT -6
Thanks Jim, I'll give that a try.
K
Post by klborschel on Mar 14, 2022 13:51:33 GMT -6
I bought this scooter used. It was driven less than 600 miles, the throttle locked up and the prior owner never fixed it letting the bike sit in the weather for years. I got it running but recently noticed the left and right fork tubes were leaking so I decided to tackle restoring and fixing the issue. My problem is parts availability and lack of information out there for comparable parts.
I need 2 fork seals, 2 dust seals and possibly 2 fork damper rod piston rings.
I have the fork seal measurements (41 x 53 x 9.5). I don't have the dust seal measurements. May be able to use the old ones but would prefer to replace. I also do not have the fork damper rod piston rings measurements. It's a white plastic ring and I estimate it to be about 30/31mm x 35/36mm x 3mm (ID x OD x thickness)
I realize this is a lot to ask, but hoping someone knows a good source for parts, be they OEM or some aftermarket version or equivalent.
Thank you.
