Post by rml6093 on Mar 26, 2022 13:07:31 GMT -6
Playing with the carb might not be the answer. Look for a cracked intake manifold or leak in the vacuum lines. The best way possibly is to start the bike and listen for a hissing noise. That could lead you to the leak. Well it won’t really run long enough to do that. Just starts idles real low and cuts off. Which is why I’m wanting to know some adjustments on the carb so I can maybe listen for that or if it just needed adjusting
Post by rml6093 on Mar 24, 2022 19:21:25 GMT -6
So I got it to start the other day, it would idle real low it seemed. I could drive it but once I would open the throttle up it would bog and cut off.
Took the carb off cleaned it and went by a YouTube video on the two screw adjustments and it does the same and almost even worse.
Does anyone know the correct turns out for each screw? Service manual? Something!
Appreciate any help I get thanks guys
