2008 TaoTao
by: gy6s - Jul 17, 2022 9:04:31 GMT -6
via mobile
Post by gy6s on Jul 17, 2022 9:04:31 GMT -6
I need some help I purchase a used 2008 50cc TaoTao It was working perfectly I did the oil change after I got . Last week it didn’t want to start I changed the spark plug the coil cleaned the carb I see spark and fuel is going through it did start 3 times for few seconds then it dies I don’t know what to do
Post by gy6s on Jul 16, 2022 19:36:54 GMT -6
I have a 2008 taotao 50 and it don’t want to run it did start 3 time and then die and don’t want to start I have good gas on it I cleaned the car changed the spark plug and the coil I don’t know what’s the problem it do have spark,gas,and everything it should need to be running can someone tell me what’s the problem
Post by gy6s on Jul 16, 2022 19:34:01 GMT -6
If you were off by one tooth the scooter would run like crap. While it's out there maybe the oil ring is stuck and letting crankcase pressure build. The easiest test would be to pull the breather house out of the air box and see if it's blowing oil when it runs.
