Post by rogercom on Apr 22, 2023 7:00:22 GMT -6
2021 Ice Bear.Q6 PST-50. MY TRIKE JUST STARTED THIS CLICKING NOISE IN THE RIGHT REAR AXLE TUBE. I JACKED UP THE REAR AND IF I TURN THE WHEEL ON THAT R SIDE,. IT ONLY CLICKS ONCE PER REVOLUTION OF THE WHEEL. I HAVE GREASED THE REAR DIFFERENTIAL. IS THERE A BEARING IN EACH AXLE TUBE. DONT KNOW WHAT ELSE IT COULD BE IF THESE AXLE TUBES ARE DRY. HOW HARD IS IT TO CHANGE THE BEARING OR CAN YOU GET TO IT TO TRY AND LUBRICATE IT.
Post by rogercom on Apr 21, 2023 14:42:18 GMT -6
My Ice Bear Trike just started making a clicking noise on the right rear axle. If I rotate the wheel or axle hub by hand. Every revolution, it clicks once. Are there bearings in the ends of the axle tubes that go bad. Behind the castle nut.It only does it once every revolution but very noticeable.
Thanks for any help.
Post by rogercom on Aug 22, 2022 17:50:33 GMT -6
Dosn,t the belt have a part number on it. Most gates belts have the number on them. Unless it can't be read.
Which OIL.
by: rogercom - Aug 22, 2022 11:35:47 GMT -6
via mobile
Post by rogercom on Aug 22, 2022 11:35:47 GMT -6
I just bought an ICE Bear Q6 50cc. Trike. The dealers web site says; DO NOT Use Synthetic Oil in the. Jinlang QMB139 Engine. But everything I see in posts,says use 10W40 Amsoil or synthetic for air cooled engines.Are the dealers web sites and info out of Date.
Which OIL.
by: rogercom - Aug 22, 2022 11:32:59 GMT -6
via mobile
Post by rogercom on Aug 22, 2022 11:32:59 GMT -6
