Post by doublec on Apr 9, 2023 9:03:01 GMT -6
I just installed 100cc big bore on my trike. I want to put a crank shaft in but not sure what to get. I used 64mm valves. Hopping for any suggestions
Post by doublec on Jan 21, 2023 16:01:15 GMT -6
Hi I'm new to the forum so please forgive me if I'm not using it correctly. I just got a 50cc 4 stroke trike... Have some plans for it.. but I'm just trying to get it running correctly. Starts fine when cold but when you give it throttle it bogs and after about 5 mins of idle it gets really hot and stalls. Then won't start till it cools. Any help would be much appreciated....
Post by doublec on Jan 21, 2023 15:59:47 GMT -6
Hi I'm not to the forum so please forgive me if I'm not using it correctly. I just got a 50cc 4 stroke trike... Have some plans for it.. but I'm just trying to get it running correctly. Starts fine when cold but when you give it throttle it bogs and after about 5 mins of idle it gets really hot and stalls. Then won't start till it cools. Any help would be much appreciated....
Post by doublec on Jan 10, 2023 14:00:29 GMT -6
Sorry to jump in but can you use a 6 pole stator with 8 pole flywheel
50cc gy6..
by: doublec - Dec 27, 2022 0:15:35 GMT -6
via mobile
Post by doublec on Dec 27, 2022 0:15:35 GMT -6
Wires are very brittle. When I move something the insulation on wires crack which I'm sure isn't good. I ordered a new wire harness and a intake manifold. Want to build this scooter. Should of asked before but will I need to up grade any wiring for 8 pole stator besides rectifier and
50cc gy6..
by: doublec - Dec 26, 2022 13:50:56 GMT -6
via mobile
Post by doublec on Dec 26, 2022 13:50:56 GMT -6
Ok will check that first.. could it be adjustment on carb ?
50cc gy6..
by: doublec - Dec 17, 2022 22:02:49 GMT -6
via mobile
Post by doublec on Dec 17, 2022 22:02:49 GMT -6
I just brought a 50cc trike. It had small issue. So I thought. After it warmed up at full throttle it would bog out. I would run it about half for a minute then be able to open it back up.. so I did a carb clean. Still doing it until one day I got stuck. No spark nothing. So I just replaced stator, ignition coil, starter relay, cdi and rectifier. Got it started. Went to take for a ride. Ran good. Then stated doing something at full throttle. It kept losing power till it died. Tried to restart battery was dead and the spark plug was melted at the top where it sparks. I'm lost. Was hoping to get some feed back before I mess with wire harness. Any help would be appreciated...Thank you.
