Post by arabellemaliya on Aug 8, 2024 6:58:53 GMT -6
It sounds like you're dealing with a common issue in moped repair. Since you've already replaced. The blinker relay confirmed the bulb is good. The next step is to check the wiring connections and the socket. Where the bulb fits. Sometimes, corrosion or loose connections can prevent the blinker from functioning properly. Start by inspecting the socket for any signs of rust or debris and clean it thoroughly. Also, ensure that the wiring leading to the rear left blinker is intact and not frayed or disconnected. If everything checks out but the blinker still doesn't work. You might want to test the ground connection. As a faulty ground can cause the blinker to malfunction. Rechecking all these areas should help you pinpoint and resolve the issue.
