Post by bturn on Jul 31, 2011 9:56:52 GMT -6
Thanks guys for your help so far. Drove it about 20 minutes yesterday (twice) and everything is runnin well. Hope to take it for a longer ride today to see how it runs.
Again thanks. Bruce
Post by bturn on Jul 30, 2011 6:26:55 GMT -6
Other side of carb if that helps to find air/gas mixture screw. Thanks again. Bruce Attachments:
Post by bturn on Jul 30, 2011 6:25:00 GMT -6
The scoot is getting better (with limited riding). Did valves .004 and .005 Idled engine to warm up for carburetor adjustment. Increased idle speed with no tach, let it continue to warm. After five minutes, just stopped. Started easily. Went to adjust carb screw and got lost. I have attached a pic of it for your review. PS drove the scoot for about 15 minutes. Turned it off, waited 15-20 min. Got back on and ran well. I'll ride longer today. Attachments:
Post by bturn on Jul 29, 2011 13:56:55 GMT -6
Adding the seat pinch image Attachments:
Post by bturn on Jul 29, 2011 13:54:23 GMT -6
Thanks for the quick recommendations. 2 items. Took all the plastic off along with seat bucket. Started scoot and gas was coming out of one of the new lines I installed. Put seat bucket back on bolt/posts - amazingly - the bucket pinches the fuel line AT the nipple and any weight on the seat increases the pinch and therefore cuts the line. So pulled out the Dremel and cut a whole in the bucket to alleviate the pinch. See pix. I took pix of the valve cover (newbie - I believe that's it). It looks different than the YouTube videos (the metal horseshoe part). Correct me if I'm wrong, this is the proper item to take off along with the metal horseshoe pipe. Again thanks. Bruce Attachments:
Post by bturn on Jul 29, 2011 11:23:16 GMT -6
I've been searching the site and haven't found the exact matching problem but close. It doesn't make sense to me.
Brand new Roketa MC 16K 150. Worked fine to about 70 miles. My wife and I were on the scooter (me 210, my wife 125 lbs). Drove for about 3 miles in urban traffic (Chicago) and scooter started to "bog' down and would stop. It would start but when giving gas it would die.
Went into destination for about an hour. Got on scoot went 4 blocks same thing. Had my wife take a cab home. I was able to get it to limp 4 miles home at about 5-10 mph. Any gas and it would die.
2 days later, went to store 4 blocks away with daughter on back (100 lbs). Came out of store, two blocks later same thing as before, limped home.
3's a charm - Drove 5 miles with only me to destination with no problem. Hour after meeting got on scoot, drove 3/4 mile same thing. Limped home.
Bought scoot wholesale and it was delivered. Took it apart and did some of the PDI, replaced all hoses (in fact the fuel line was delivered with a cut in it), put in new fuel filter, adjusted idle (not carb, was not sure which screw - now I know), did NOT do valves.
I just bought feeler guage and am going to garage now to learn/work on adjustment. .04 intake, .05 exhaust.
Thank you in advance for any guidance, additional ideas and your help. PS I am assuming this engine is a GY6?
Imported by JMSTAR Powersports, Inc MFG: April 2011 Engine Displacement 150 cc Engine Family, BSJMCO 15FKD Permeation Family: BSJMPMETALKT Manufactuered by Taizhou City Kaitong Mortorcycle Manufacture Co. LTD
On engine plate: md150t-11
Crank Case kt-V110429123 BSJMCO.15fkd
Bruce
