Post by Gort on Feb 3, 2013 13:18:01 GMT -6
Thanks for the replies and link guys they helped. I found a diagram of my tank on a parts warehouse site. It isn't a fuel pump under the tank so it must be the gravity feed. 12 is listed as a petcock and 2 is a vacuum line. So It looks like the vacuum line opens the petcock and gravity does the rest. I ran into a couple forums where they said the vacuum petcock was lame. They said it was better to replace it with a manual valve like on a motorcycle. What do you guys think and where would I get one?
Post by Gort on Feb 2, 2013 5:35:11 GMT -6
I picked this up dirt from a friend who eeded the money. This is a motorcycle but my friend told me that it's scooter under the body. I don't know how to post pictures but I found this on Google image. That picture is definately my motorcycle. I think my friend is right because it doesn't have a clutch and you don't shift gears. So if it has scooter parts I thought you guys could help. The problem is that no gas is getting to the carb. I know because I pulled the hose off and cranked the motor. No gas came out so I think the fuel pump is broke. There's a siver disc on the fuel tank and I guess that's the pump? I could use some advice here because I don't want to brake something and have to spend more money.
