Post by michaelrulaz on Dec 19, 2011 1:12:17 GMT -6
Hello, i have a gy6 velocity 150 scooter. i bought it two years ago and it ran great then i lost the key so it wasnt used for some time. when i went to use it we couldnt get it to start, found out by testing the air filter it wasnt getting gas and we played around with it and eventually cleaned the carb. now i am not good with the names of the parts but recently we made it gravity fed because we thought the petcock was bad but we tested it and it wasnt.
so now: i reattached the fuel lines to a fuel flter then the peakcock, then the fuel line to the carb.
Attached fuel vapor line to canister
then the vaccum line has two Ts it starts in the carb then it breaks off to other stuff (we didnt unplug) one goes to the petcock, the other to the canister.
the canister is missing a cord i believe. because i have a thick gage air line (i believe) that has an elbow attached to it. i dont know where it goes. any suggestions, ill post pics in the A.M. its turning over but wont crank up when playing the vacuum lines it sounded like it would crank over once but didnt. it has fuel and i dont know if this matters but when i put the key in and turn it to the on position the lights and gauges no longer work (possible fuse, but its automatic stuff) but i can manuelly turn the blinkers on and the breaks work. please i need help, i just blew a head in my ninja500 so this is my only vehical. thanks everyone
