Post by boosthb on Feb 6, 2012 0:19:09 GMT -6
Ok. Compression tests yielded a best of 75psi. However, I think I've found a source for a new head gasket.... looks like I'll be pulling the head again, but at least this time, I can do a better job of getting TDC. Hey brotha I too have the same engine I got it from Scrappy Dog scooters and the I checked the compression it was at 175psi. yours seems to be too low. While checking compression did you have the throttle opened all the way cause if not it will read low.
