Post by 8744675 on Aug 16, 2014 13:30:25 GMT -6
I have the same issue. 1 headlight is dim, the other out. 2 different bulbs, one a 70 watt H1 Halogen bulb that's way to hot for the small enclosure. The other is different. Both only have 2 electrical connections. I ordered new bulbs that are supposed to be the stock bulb for a Lancer 150, but they have 3 connnections (hi/lo beam and ground, and there are only 2 wires from the harness.
Does anyboy have a wiring diagam or picture to show what it should look like under the headlight shroud?
Problem #2, the engine bogs and then makes a loud bank when trying to start it with the electric starter. It's much louder than the usual one that sometimes occurs. It sounds like somebody wacking a metal pole with a steel flat bar. It's hard to find the spot where I can let up the starter and give it some gas without it hanging up and banging. After about 3 short tries, the battery is drained. I've used 2 different batteris and took the starter off and checked it for shorts. Once it starts, it runs ok. I have to carry a spare fully charged battery under the seat for when it won't start by the 3rd try.
I'm going to check the valves next. I'm thinking they aren't opening and compression gets too high for the starter to overcome. The bike runs fine once it starts, but randomly will stall out when I stop. Other times it idles around 2000 rpm and some times it idles around 3,000 rpm. Does anybody have any ideas? I'm hoping I won't have to open it up and check the starter clutch.
Problem 3, when I pull the brake lever, a red light on the dashboard lights up. I thought that was for the emergency flashers. I have a Jmstatr 150 that's nearly identical, and it doesn't do that. I just checked the brake light in back, and it gets only slightly brighter when I pull the lever, but not enough for someone to behind me recognize it. I'm thinking some wires are crossed.
Does anyone have a wiring diagram, or picture to show the wiring for the lights? Also, any ideas about the other issues will be greatly appreciated. I've searched and searched for similar issues, without much luck.
Thanks
