Post by drbenz on Dec 15, 2014 6:32:10 GMT -6
You might try one more thing, take off the right side fan shroud and turn the flywheel to where the metal bump that tells the cdi to fire is under the pickup (straight up). Take a business card and see that the gap is between a card thickness and two card thicknesses (somewhere between .010 and .025). If that gap is too large the cdi may fire but the spark will be weak. I hate to tell you how long I worked to find that one - everything checked ok!
