Post by bmxkillhorse on Apr 10, 2012 9:37:18 GMT -6
well needle was a bit gummy and cleaned it out she started right up no problem seems to be running fine now....
thanks everybody
Post by bmxkillhorse on Apr 9, 2012 13:29:13 GMT -6
Cool Ill be sure to do that tonight and ill let yall know if its on the road again tomorrow...
Post by bmxkillhorse on Apr 9, 2012 13:07:29 GMT -6
thanks alleyoop
Post by bmxkillhorse on Apr 9, 2012 13:06:25 GMT -6
Thanks Niedz, The float seemed to be working fine when i cleaned everything but i can always try and clean it again if the solution is as simple as that... Ill try that again tonight after work it seems like that is the issue which makes sense, ill just try and meticulously clean the float but if anyone has any other ideas of what to do or if it could be something else im open for some inquiry ...
thanks all
Post by bmxkillhorse on Apr 9, 2012 9:09:24 GMT -6
so my girlfriend has a sunn 150cc that sat around for maybe 5-6 months so before i started it again i took off the carb soaked it overnight in cleaner and put it back on the next morning she started right up but after about 15 secs of idle she starts dumping gas out of the carb overflow tube im assuming is what it is but i dont know what to do any help would be much appreciated. thanks all Attachments:
