Post by cranky68 on Jun 21, 2013 13:38:32 GMT -6
Excellent! Thank you very much. Where could I find a new one?
Post by cranky68 on Jun 21, 2013 11:27:09 GMT -6
I ran a test on my auto-choke and I believe it is bad. PLease look at the attached pictures and let me know if it looks like the auto-choke is operating properly. The manual said that the tipo should extent 3-6mm but it looks to me like the "base" extened not the needle tip. Could this cause a scooter to not start? Attachments:
Post by cranky68 on May 6, 2013 19:17:59 GMT -6
Post by cranky68 on May 6, 2013 18:45:23 GMT -6
Jemstar 250cc (carb jet location pictures attached) I cannot seem to get my scooter to start without pouring gas into the cylinder. I would prefer to not go through all of that trouble just to go for a Sunday ride. Inside the float chamber there are three separate jets. How do I know they are adjusted properly? I cleaned the carb a while back and did not note how many turns in/out the jets were to begin with. The scooter started well before I messed with the carb. I felt it needed to be cleaned because the scooter ran a little rough. Attachments:
Post by cranky68 on Jul 26, 2012 13:39:08 GMT -6
When I have gotten my YY250T up to highway speeds the windshield "folds" back. Is there a vendor that makes after market windshields that can withstand cruising windspeeds?
Post by cranky68 on Jul 26, 2012 13:32:57 GMT -6
Hello again, all; Now that I am getting this beast up and running again, I have other areas of concern. Where can I find a new or rebuild coolant fan? I also remember reading somewhere on this site about typical overheat issues with the JMSTAR YY250T. If I remember, someone mentioned the fact that the fuel tank impedes sufficient airflow to the cooler. Is any of this true? What has anyone found to be a good work around for this?
Post by cranky68 on Jul 26, 2012 13:26:37 GMT -6
Thanks Magoo, Do you have a picture of the air/fuel mixture screw? Or where, in relation to other componenets on the carb, I could find it?
Post by cranky68 on Jul 26, 2012 11:18:16 GMT -6
richardthescooter2, in your post you mentioned the air/fuel mixture screw, where is it located on the carb? Do you have a picture?
Post by cranky68 on Jul 26, 2012 11:15:00 GMT -6
OK. I cleaned the carb, blew out all of the jets. It will only start if I prime it by pouring gasoline into the cylander. It will not idle but does run rather smoothly. Are there factory presets for the jet adjustments?
Post by cranky68 on May 11, 2012 11:52:18 GMT -6
Wow! I was not sure what to think of this site. You "guys" responded very quickly. Thank you. I plan on working on the bike this weekend. I will let you know how things went. Again, thank you all. Very impressed.
Post by cranky68 on May 8, 2012 12:38:54 GMT -6
Hello all. I am new to this site but am glad I found you.
Here is my dilemma. I bought a Shanghai JMsport YY250T two years ago. I had some overheat issues. I have had some wire burn issues. I have had some battery recharge/alternator issues. It has been in the garage for the past year or so without being ridden. I removed some fairings on it recently to chase suspected wire issues. The coolant fan needs to be replaced because the wire harness insulation has melted. I took care of that issue with electrical tape as a pacifier for now. The main problem is that it will not start. I replaced the spark plug and inspected the fire; it has good spark. I then put new gas in the tank (there may have been a little over a quart in it while not being ridden). I disconnected the fuel line at the exit side of the pump and tried to turn the engine over. Fuel squirted out which tells me the pump is working correctly. I then removed the spark plug and poured about a shot glass in the cylinder and then replaced the plug and turned it over again. It started and ran for a second or two, long enough to burn through all of the fuel in the cylinder.
Does anyone sell a carburetor repair kit for a pd30j carburetor? Is there something else I should check before I suspect a dirty carburetor?
