Post by stevensonrc on Jul 15, 2012 15:21:42 GMT -6
Hey all I have been working on a 2007 sunl 250-22 and it recently quit during a ride into town (about 5 miles). I had gone perhaps a half of a mile when the darn thing up and quit on me. It was running smooth then when I pulled up to a stop at a one lane bridge it was running one minute then the next dead. The engine quit all gauges died no indication of power. I have currently tried the following:
1. Trickle charged over night 2. Replaced the starter coil 3. Replaced the solenoid 4. Replaced all the fuses & fuse box
Nothing changes. I turn the key and no power. I erplced the iginiton coil, and the solenoid no change. I noticed if I put a jumper across the solenoid the starter tries to crank, but it doesn't quite turn over. I noticed when I replaced the fuses that some of the wiring between the wiring harness and the fuse box was melted, so I replaced the fuze box. I am still not getting any electricity to the starter or the gauges. If some one could give me their opinion as to if I should replace the entire wiring harness and if I should try to find a sunl or use a rocketa instead, as most of these are basically the same scoot with different branding.
