X-Speed 50
Post by craigftaylor on Jul 19, 2011 22:00:46 GMT -6
The valve adjustment is a piece of cake on this scooter. I bought one too, because I couldn't pass up the price. To adjust valves, loosen the adjuster bolts and pish each adjuster outward until first resistance is felt, back it off one tick mark, then fix bolt. No need to remove valve cover on these engines to adjust valves.
I'm having a cooling issue where the coolant is blown into the reservoir at high throttle settings. My head is flush, as I just took it to a speed shop and had them plane it. I installed a new head gasket too. Having eliminated that problem, why am I losing all my coolant to the reservoir?
