Post by larryhobman on Feb 24, 2016 18:44:53 GMT -6
I run a #88 or #90 I keep switching trying to see which is better. I have tried a #92 which was not too good. I run a 72cc (47mm piston kit) with a A9 cam I would check if you have the 44mm or the 47mm if it is a 44mm stay with the #85. Also I run a #34 idle jet it is better in the cold than the #31 I tried. Adjust your A/F screw too.
Post by larryhobman on Jan 16, 2016 21:40:13 GMT -6
Hi, What is the lowest you could do for the parts, I don't want to send a offer that is too low and insult you. My budget is just not really there and I need a new top end. Let me know.
Thanks Larry
