Post by heavyb121 on May 25, 2013 15:11:25 GMT -6
How do you know when the fuel/air is adjusted right?
Post by heavyb121 on May 18, 2013 19:04:14 GMT -6
Here is a picture Attachments:
Post by heavyb121 on May 18, 2013 19:00:58 GMT -6
There is no adjustment screw
Post by heavyb121 on May 18, 2013 6:19:33 GMT -6
Ok yea I was just adjusting it from the screw by the throttle I'll try this today
Post by heavyb121 on May 17, 2013 19:43:52 GMT -6
Fuel Ratio Mixture where is that on the carb is it by the throttle
Post by heavyb121 on May 17, 2013 17:44:22 GMT -6
So I got it running with new carb tried new spark plug also but had to put the old one back in wouldn't fire also would not go over 25mph at 5 rpm full throttle any ideas on how to speed it up or why new plug wouldn't fire
Post by heavyb121 on May 17, 2013 12:28:17 GMT -6
Could that be what's wrong with the idle
Post by heavyb121 on May 17, 2013 10:29:55 GMT -6
well nope it don't have the 2 screws on the side Attachments:
Post by heavyb121 on May 16, 2013 22:22:59 GMT -6
I'll double check in the morning.... thanks for helping me out
Post by heavyb121 on May 16, 2013 17:43:27 GMT -6
Yea it has the 2 screws that hold it on so you can just deactivate it
Post by heavyb121 on May 16, 2013 16:59:39 GMT -6
It don't look real bad but the enricher isn't hook up I need to get the little clamp that holds it on but other than that looks pretty new also by the enricher on the carb it looks like a vac hose might be missing but I'm not sure
Post by heavyb121 on May 16, 2013 15:07:01 GMT -6
The starter just wasn't turn we took it out and clean it and put it back on and it worked so I'm guessing that the starter is going bad I'm at work now but tomorrow I'll take some pics of the carb and post them but I'm pretty sure that throttle cable is is on the right side and on the left side it has a electronic choke
Post by heavyb121 on May 16, 2013 12:58:20 GMT -6
alright so I got the moped to start but I can't get the rpms to go above 1 any ideas on that also to get it to start had to take starter off and free it up and then it started
Post by heavyb121 on May 12, 2013 14:53:33 GMT -6
ok thanks I'll let you know how that goes
Post by heavyb121 on May 12, 2013 9:00:35 GMT -6
Ok when I touch the solenoid it didn't do anything but when I tried to start normal all I get is click click from the solenoid
