Post by mhendrix12 on May 14, 2013 13:13:05 GMT -6
i did that, and the results were just as you stated above, for the one i have runnin, but this one produces no electricity from either the blue or red/black.
think i just need to change the stator? they're either good or bad, aren't they?
Is there a timing mark you have to adhere to, for the pulse voltage?
Post by mhendrix12 on May 13, 2013 21:44:23 GMT -6
I meant the pickup that's stationary to the stator. What would cause one of these to stop producing electricity, a short in one of the windings?
I guess what i was asking is if why when i'm cranking it over, i get a voltage on the white and yellow wires that are for the lights, and charging, but no voltage from either of the other two, that go to the CDI
Post by mhendrix12 on May 13, 2013 16:25:43 GMT -6
Hey y'all,
I've got a GY-150cc and have lost any electrical current from the stator, to the CDI. I have voltage for the lights, and charging system. Not problems normally encountered on a 1 yr old engine. Which would be more likely the suspect, the stator, or the pickup?
