Post by dpinney on Jun 25, 2013 15:58:56 GMT -6
It looks like the second picture. Which type is it, the messy one.
Post by dpinney on Jun 25, 2013 15:20:20 GMT -6
I am repairing a Wildfire WFH250T2. The engine looks like the YY250TT. It had intermittent spark that quit after a couple minutes. There is no AC Pulse from the Pulse Coil. Impedance of the pulse coil circuit is only 120 Ohms. The AC Power from the stator is normal for the lights and Voltage Regulator.
I suspect that the spark coil on the stator is bad. Does anyone agree? I have a couple of questions for anyone that has changed the stator. It is obvious that lube lines must be removed and the oil drained. Is it possible to replace the stator without removing the coolant hoses? Is the Magneto cupped in or out? does it need to be removed? Any Suggestions.
This looks like a big job, and I do not want to make it worse by making errors.
Thank You!
