Post by justlucky on Sept 12, 2010 9:04:33 GMT -6
Thanks for the info. Found the problem. When the master cylinder resivor holes were drilled in the bottom for the fluid to travel thru the back hole was not drilled all the way. I removed the resivor, drill the hole and honed the cylinder. Put it back together and bleed the brakes. Finally I have front wheel stopping power. Thanks again for the info.
Post by justlucky on Sept 11, 2010 13:16:29 GMT -6
Working on a peace scoot. I am in the process of bleeding the front brake system. I'm getting solid fluid flow but very little resitance at the handle and hardly any stopping of the ft wheel. Wondering about the abs componet. Can anyone tell me how it works? If it is fautly will it be ok to remove the abs valve and attach the brake line directly to the caliper? Thanks in advance for your help.
