Post by robste71 on Dec 2, 2013 17:21:03 GMT -6
Cranks strong, nice and blue after new plug install. The line sucked up some gas but would not start so took line out of gas and it went down then tried again would not start and pulled line out of gas it was full and did not go done in line. Kicks over fine I feel compression when kicking over but use electric start most of the time. Don't see another ground will try to run one. Will check gas flow tomorrow fuel fills new filter when I put a pull on the vacuum line.
Post by robste71 on Dec 2, 2013 16:47:33 GMT -6
Yes gas got sucked up at first then stopped. Kick start works. Bike fell on left side. will post pic tomorrow. Intake looks ok. Only ground I see comes from right side of motor to battery negative.
Post by robste71 on Dec 2, 2013 16:12:10 GMT -6
if cdi was bad would I get spark at plug. sorry not sure of these bikes
Post by robste71 on Dec 2, 2013 15:31:34 GMT -6
Added gas to the vac line. same thing no start
Post by robste71 on Dec 2, 2013 15:10:26 GMT -6
Could it be valve adjustment? It ran fine before this. Hole in the piston?
Post by robste71 on Dec 2, 2013 14:58:34 GMT -6
Installed new plug no start. Took plug out and grounded with plug wire on and a lot better spark. This is driving me crazy!!!
Post by robste71 on Dec 2, 2013 11:12:39 GMT -6
Sprayed starting fluid nothing. Can smell starting fluid coming out exhaust. Also checked kill switches all intact. going to try and bypass them and see what happens. Will check vac lines but already went over them but will again
Post by robste71 on Dec 2, 2013 8:50:51 GMT -6
Hello everyone new guy here. Im trying to repair my girlfriends scooter with not much luck. Its a 08 BMS Pathfinder 200. It ran great til it fell over and now it wont start. Took air filter a part and cleaned, carb cleaned. Its getting fire at plug. Put new gas in it. Carb getting fuel. Brake light comes on when push both brakes. Im lost any ideas?
