Post by squall8ball on Mar 4, 2014 13:13:55 GMT -6
well its a shame no one lives close to me! its perfect weather now and i would love to hit the open road for a few!
Post by squall8ball on Jan 31, 2014 10:27:12 GMT -6
actually, it was a combo of several diffrent things, the a/f mixture screw was turned out WAY too far, leaned it out a bit and the stator drive shaft has the teeth grinded down... only a 4 hour fix now it runs like a champ! thanks again!
Post by squall8ball on Jan 28, 2014 17:06:48 GMT -6
who?
Post by squall8ball on Jan 28, 2014 14:48:34 GMT -6
found the issue! its the stator! its catching on something inside the motor! taking it to a shop 2morrow to get it fixed! thank god! thank you alleyoop for all your troubleshooting help!
Post by squall8ball on Jan 28, 2014 13:41:05 GMT -6
Post by squall8ball on Jan 28, 2014 12:49:00 GMT -6
looking to get some people together for a ride here in the near future... the weather is perfect and just want to go and do some site seeing!
Post by squall8ball on Jan 28, 2014 12:36:58 GMT -6
well the new ground didnt help, and its getting a good hot spark to the plug and the plug is extended to it correctly too...
Post by squall8ball on Jan 27, 2014 19:19:15 GMT -6
well there is no ground from the valve cover to the frame at all! there is one from the tank to the frame, and this is a rebuilt motor prior to me buying it. no new parts since i bought it minus a tire. no multi meter on hand. will get one tommrrow and test those, will get back to you when i test them... what should i be testing for exactly?
Post by squall8ball on Jan 27, 2014 18:51:28 GMT -6
the spark plug is brand new and gaped properly, one other thing i forgot to add in was this started suddenly while i was riding it.
Post by squall8ball on Jan 27, 2014 17:48:20 GMT -6
i yamaha bonded the intake gasket to the carb, and at the moment it is running of strait carb. still nothing...
Post by squall8ball on Jan 27, 2014 15:16:59 GMT -6
hi! i am new to this board, and i am kinda new to scooter repair as well. I have a major issue with a 2008 ktmmx 150cc racer scooter where it just idols rough all the time. even on throttle it just has a hard time getting up to speed. it acts like it is not receiving enough air. when i pull the vacuum line of the manifold, it idols up, but does not fix the problem. i have adjusted the valves, replaced the cdi, replaced the spark plug and wire, new carb, new choke, but all still to no avail! i have also checked the a/f mixture, and checked exhaust thoroughly, along with vacuum lines. checked fuel filter, and gaskets throughout. please help me! as i am lost, and so is my mechanic! he has over 25 years in this field!
thank you in advance for any and all help you might be able to give me! here is a short video of what it is doing.
