Post by cattin5 on May 4, 2014 15:00:24 GMT -6
Post by cattin5 on May 4, 2014 13:29:44 GMT -6
I replaced the regulator and did not fix the problem. I cant seem to find where the stator is located (seems to be easy to find on other bikes) or if it even has one? The model is a Sunl 250t-29
Post by cattin5 on Apr 26, 2014 16:47:37 GMT -6
and yes my light switch is on the right side but the the lights turn on and off just fine.
Post by cattin5 on Apr 26, 2014 16:44:02 GMT -6
Thanks for your reply, but the motor is running when the lights are on, and I can go cruising on it for hours with no problem, it's just when I kill it and try to restart it it seems to have drained my battery and sometimes it starts sometimes it does not, but you're probably right about the lights.
Post by cattin5 on Apr 26, 2014 15:37:25 GMT -6
I have done the voltage test on my battery to my Sunl 250CC scooter and it is showing that the battery is charging, however when I turn the lights on the voltage starts to drop and starts to drain my battery. It does not seem to have a problem when it's running, no dimming lights or anything that would show it's draining, just when I kill it and try to restart it does the battery seem to have drained. I did install some brighter lights in sometime back, could this be the cause?
