Post by mhyquel on Jun 11, 2014 21:43:26 GMT -6
The problem started when I bought gas from Safeway. I've since a tank through though.
Post by mhyquel on Jun 11, 2014 20:27:32 GMT -6
Did you pull the jets and inspect the tubes?
Pulled the carb apart and put it back tonight.
Tubes and jets look fine. Slide diaphragm is good. Spark plug is a little black, and dry. Seals on manifold are good. Tried with the tank cap off, and still has issues. Filter and air box are good.
Runs perfectly fine at low rpms. When I give it full gas, it stutters. With bursts of ignition. It will also stall and die after running for ~10 minutes. Starts up fine after stalling.
Post by mhyquel on Jun 11, 2014 9:25:41 GMT -6
Hi Jvino,
It's a 150cc Saga, made by Benzhou.
It has ~6000km on it.
Post by mhyquel on Jun 10, 2014 23:42:41 GMT -6
My 2009 benzhou developed a problem recently. Starts fine, runs at low speeds fine. When I try and get above 30kmh it won't rev higher. It starts bogging down, and sputtering. I've stripped the carb down, totally clean. Its getting a good spark, air filter is clean.
Please help!
