Post by jwhood32 on Jul 26, 2014 9:21:02 GMT -6
I told ya not too take it there they are a rip off they have know idea what they are doing on 2 strokes,tom did u take it to tank scooters on eastern ave??
Post by jwhood32 on Jun 29, 2014 21:21:57 GMT -6
These carbs get dirty also the smallest piece of dirt will clog up the jets or could possibly be and airleak somewhere pull the plug and let me know what plug your running or your cdi could be going bad
Post by jwhood32 on Jun 29, 2014 12:11:28 GMT -6
Yeah if u keep having issues with the petcock u can convert too a manual fuel on off and cap the vaccum line hole off on the carb,also you should look into getting a 17.5 mm carb that will give u a little more fuel delivery and there is a restriction ring on the variator that cause the variator not to close all the way causing you too top out at like 35mph!!!Also the Speedo is way off your actually not going as fast as Speedo says it's of between 8-12 mph GPS your speed will give better idea on how fast your going
Post by jwhood32 on Jun 29, 2014 11:43:14 GMT -6
Sent you a pm,filter looks pretty good too me is there any oil residue in the airbox and I would clean it with warm soapy water rinse out and 're oil the filter with some filter oil or the good 2 stroke oil I use amsoil interceptor oil you can get at salvos auto parts it's like $9 a bottle it great oil,dump a little of that In a Ziploc bag and put filter in Ziploc seal it and get filter oiled take it out and pop it back in and filter box!!!
Post by jwhood32 on Jun 29, 2014 10:06:10 GMT -6
Tom do not ever take your scooter to tnk scooters on eastern.ave they have no clue what there doing period,trust me from past experiences!!!
Post by jwhood32 on Jun 28, 2014 22:58:40 GMT -6
I run premix these things are notorious for the oil pump going up and locking the engine up cause u have no clue it stopped working,I also have a red r50x that I'm in the process of building and I'll be removing the oil pump on this also just giving u some suggestions on saving your self the pain and hassle of rebuilding the motor on yours!!!
Post by jwhood32 on Jun 27, 2014 14:26:32 GMT -6
No problem bro these bikes are touchy as hell let me know if u need help with anything
Post by jwhood32 on Jun 27, 2014 0:09:30 GMT -6
I have 2 Tgb scooters and from my experience you have too use 93 octane and I also add isoheet to every other tank fill up to get water out of the fuel,I also live in Baltimore,man that's a far trip too ride back where did you buy scooter from if you need any help let me know I've been threw the ringer and back with my Tgb,also might wanna take carb off and clean it also!!!
