Under the speed limit, above the law.
Post by salsashark on Jun 25, 2014 9:44:32 GMT -6
I recently had a tire pop a leak and slime sprayed all over the underside in the back. I haven't been able to get all of it cleaned out. This morning I noticed a few drops of green fluid on the back of my belt box. It's watery and not thick like tire slime should. be. I'm worried that it could be break fluid. I hope it's melted slime. What color is break fluid supposed to be?
Post by jct842 on Jun 25, 2014 9:55:51 GMT -6
BRAKE fluid is clear. Goes amber with age.
Post by salsashark on Jun 25, 2014 10:51:20 GMT -6
Using my power to watch instructional videos on youtube, I learned that watery green fluid is coolant. Now I have to figure out whether I need to add coolant. The scooter is only three months old with just over 1000 miles on it. It's Chinese, so it needs a lot of tenderness. Is there an overflow reservoir that might throw a little coolant on a bumpy ride? And if so, might I need to add coolant?
Post by Deleted on Jun 25, 2014 11:44:34 GMT -6
your scooter is air cooled. no coolant.
Post by cyborg on Jun 25, 2014 11:54:48 GMT -6
It may have been a sealant inside the tire that sprayed out
Post by LUKE on Jun 25, 2014 15:30:18 GMT -6
smell it, brake fluid should smell a bit like petroleum-ish, slime smell like bubble gum... you can very well distinguish them from each other.
no cyborg, dont taste it....i still cant get over your $140k motorcycle modification budget.. ooooh, you must be richer than mayweather hahaha
Post by cyborg on Jun 25, 2014 17:11:18 GMT -6
i liked it much better when i blocked your posts,,,so i guess i'll go back to that
