Post by globetrotta on May 21, 2015 2:15:53 GMT -6
Post by cyborg on May 21, 2015 6:20:42 GMT -6
The one on the left
Post by globetrotta on May 21, 2015 22:01:33 GMT -6
Thanks! So the one in the middle is for the Evap? And what about the broken piece on the right? Thanks.
Post by dmartin95 on May 22, 2015 12:07:41 GMT -6
Thanks! So the one in the middle is for the Evap? And what about the broken piece on the right? Thanks. I'm not sure Cyborg called it correctly on this one... Your valve cover vent goes to the one next to the one that's broke off... The broken one I believe is just an air vent. Your other one ties into your vacuum lines. I can double check, I have a few of these out in the shop.
Post by Alleyoop on May 22, 2015 12:28:47 GMT -6
#1 is for your EVAP SYSTEM(from Gas Tank Canister), #2 is for the Valve Cover Vent Inside you should have a small foam filter, #3 is the drain for the Oil collected from the Valve Cover Vent. See the HOSE WITH THE OIL IN IT that is #3.
Post by globetrotta on May 22, 2015 12:53:06 GMT -6
Thanks Alley, so if I deleted the EVAP system, I'll plug hole #1 correct? Valve hose goes to #2 which I'm assuming is an air/oil separator. #3 though broke off for me, should I just leave it open or make a new piece to put the hose on?
Post by Alleyoop on May 22, 2015 13:12:44 GMT -6
Yes if you take the EVAP system off PLUG #1. I would also Plug #2 and #3 up. Take the Valve Cover Vent and Put a Fuel Filter on the end of it and ZIP TIE IT HIGHER than the Valve Cover. That way if it squirts out oil it will drain back into the valve cover. This way you have less possible things that can go wrong on you. Alleyoop
Post by globetrotta on May 22, 2015 13:16:04 GMT -6
Awesome, thanks a bunch.
I'm hooked, I love the 2 wheel riding experience!
Post by townzlblx150 on Jul 6, 2015 12:39:24 GMT -6
I tried putting a fuel filter on the valve vent hose, after going about a 1/4 to 1/2 a mile my scoot shut down twice. I removed the filter and it has been running fine. My problem is, it seems there is some oil that is getting through the hose. As soon as my air filter and carb come I'm getting rid of the air box, so I can't reconnect it to the box. Any suggestions?
Post by Alleyoop on Jul 6, 2015 12:57:17 GMT -6
SAY WHAT!! is the fuel filter getting clogged with OIL? Is the Hose zipped tied HIGH higher than the Valve cover WITH NO KINKS, remember it has to VENT. So take the Fuel filter off and zip tie it high so if it squirts oil into the hose it will drain back down. Alleyoop
Post by townzlblx150 on Jul 9, 2015 5:15:02 GMT -6
I'm gonna have to get the taste of crow out my mouth on this one. You were right on this one Alley, your instructions on the valve vent hose were correct. After installing some new parts I took it out for a test and it died again, so the next day, after work I did some troubleshooting. I got it running and let it idle for 5-10 minutes, then checked my fuel filter, next I sprayed down vac hoses with carb cleaner checking for leaks. I was about to start looking at electrical connections when my brother in law touched one side of my coil feed wires and it almost died, Eureka! One of the connections was really loose causing it to jar loose from vibrations and give me a bad connection. It's running good for now, still need to tweak the new carb, I'm having a backfire issue, but I did reinstall the fuel filter on the valve vent hose and no issues, Thanks.
