Post by xxxposed on Jun 2, 2015 10:19:01 GMT -6
Had loose spark plug boot that would come off, sometimes it would pop off while riding. Well it did that yesterday on the frwy. However this time it would not start. The clamp w clip inside the boot that attaches to the spark plug end,no longer holds and shape has been distorted. Cant find screw on boots anywhere,and no time to order.i have an old tao tao atv that i tool the boot off and screwed on,and it still doesnt work. The engine is trying to crank and the starting mechanisms sound pretty strong. I am positive this is a Sparkplug issue or atleast the result of a Sparkplug issue. The plug itself never came out if that helps
Post by Alleyoop on Jun 2, 2015 11:55:04 GMT -6
Well check for spark, Take the plug out and stick it in the boot and ground it to the motor and crank it and see if it is firing. Alleyoop
Post by cyborg on Jun 2, 2015 11:59:58 GMT -6
I've had more than one plug go bad,,,,
Post by xxxposed on Jun 2, 2015 14:18:19 GMT -6
Have spark , also tried 3 seperate plugs. Its trying to start,just wont turn over
Post by Alleyoop on Jun 2, 2015 15:04:09 GMT -6
Well if it sparks then it may be lack of fuel, crank it and pull the plug out and see if it is wet or dry that will tell you lack of fuel or to much fuel and or plug not firing while in the motor.
What if anything did you do or add or take off before this started to happen? Alleyoop
