Post by Alleyoop on May 15, 2016 13:57:02 GMT -6
Maybe it is just the motors vibration you are feeling, the motors do vibrate back and forth, which you should be able to see the mirrors moving a little bit.
Post by icebear2009 on May 15, 2016 15:19:15 GMT -6
Yeah maybe ill keep a eye on it and see if it gets any worse
Post by icebear2009 on May 15, 2016 15:21:12 GMT -6
Hey by the way I did both my brother in laws and sisters scooters gear oil change I warmed them up the drain it out and only got 4 ozs out and refill would only hold 4 ozs and they both have the 157qmj is that normal because I remember u saying 8 ozs
Post by Alleyoop on May 15, 2016 15:41:30 GMT -6
Well mine takes 8oz BUT mine is a Trike BUT it has the extra case for the Reverse Gears so I misspoke saying it takes 8oz's for your regular two wheel scooters. Sorry I just think of mine at times and your right HALF of what mine takes which is 4oz. Alleyoop
Post by icebear2009 on May 15, 2016 16:23:46 GMT -6
OK but with minded being the trike I will hold 8 right and just put it three vent tube right ? No where else I gotta fill up because of reverse
Post by Alleyoop on May 15, 2016 16:39:32 GMT -6
If yours has the reverse casing on the right side like this then it takes 8oz, it is just like mine. No where else is needed the casing has a hole so the oil on the gear side that you are filling flows into the reverse casing side. Alleyoop
Post by thecableguy on May 16, 2016 8:13:48 GMT -6
My Ice Bear 150 scooter (2 wheel) does the same thing, I can feel increased vibration when I hold the rear brake at idle. Idle speed is around 1600, and no, the wheel does not turn on the center stand. I just figure that with the brake shoes engaged, there's a more solid connection between the motor vibrations and the tire/ground, amplifying the vibrations. It's done it since I got it...
Jim
Post by cyborg on May 16, 2016 12:46:12 GMT -6
Yep I agree mine has a distinct vibration that is more if I'm at a lite with the brakes on
Post by icebear2009 on May 16, 2016 14:35:57 GMT -6
OK so nothing to really look at then ? It just seemed like all of a sudden but maybe I was never really paying attention either
Post by dyoung1167 on May 22, 2016 15:04:12 GMT -6
i'm not sure why but i get this too, always have. something about making the tire more ridged with the brake tight at idle and sitting still allows the normal vibration of the motor to be more pronounced though the frame. it has never caused a problem though.
