Post by cyborg on Jun 28, 2016 22:34:51 GMT -6
Acetone will get rid of the wd,,,,do yourself a favor and get an impact,,,they are a wonder
Post by rosiemoto on Jul 2, 2016 10:44:56 GMT -6
What is the stock contra spring rated? Is it 1000rpm? I want to go with stock... is the $20 NCY really worth getting over the chinese $8 contra springs??
Both my stock clutch and eBay clutch I bought have like a black or dark colored spring. I'm thinking to just buy a new contra spring if I'm able to open up the clutch.
So the belt sliding all the way back up after I squeeze the clutch pulleys apart I assume must be a sign of contra spring being worn/too weak and not putting enough tension on the belt. edit: WAS THE BELT! The belt is only a week old and is already shredding. I put my previous chinese belt and it didn't slide. Brand name of the bad belt is: Xing-Fang VS Belt
Post by cyborg on Jul 4, 2016 20:59:40 GMT -6
Good glad you sorted it out
Post by jct842 on Jul 4, 2016 21:15:31 GMT -6
bando's from a reputable dealer are cheaper in the long run!
Post by i1blaq1 on Jul 4, 2016 23:42:40 GMT -6
On my 90cc I put the red contra spring in and every belt I put in there ripped up or flip over,purchased & changed clutch and contra spring with a Kevlar belt didn't have that problem again.
My 2 cents.
Post by dyoung1167 on Jul 5, 2016 21:45:12 GMT -6
take a carefull look at the alignment of the cvt and clutch. i went through belts bad with my first scoot and noticed how out of whack it was, but of course, only after getting a new scoot. an extra and not needed or needed but not there washer can be a big difference
Post by rosiemoto on Jul 5, 2016 21:53:04 GMT -6
dyoung - I'll take a look to get an idea how it's aligned. So, basically you mean the belt should be straight and not curving from front pulley to back pulley, right?
Post by rosiemoto on Jul 21, 2016 23:32:22 GMT -6
Update: do NOT drill holes anywhere near the variator fan!! I decided to drill a few extra beside the intake thinking it'll suck in more air...WRONG! After a 7 minute ride my whole CVT cover was deadly hot.
Explanation: I'm pretty sure it's because the fan's airflow starts escaping the front where the holes are drilled, and so half the air never gets to the rest of the CVT. Well I duck-taped those "bad holes" back shut and the cover has become touchable and holdable again after a 20 min ride..much better. Glad I caught that!
