Post by ramel125 on Mar 21, 2017 11:45:56 GMT -6
I've been looking everywhere to get my 150cc gy6 Icebear fixed but there isn't anywhere close. Last month my bike worked fine a week later it started bogging and now it doesn't start.I checked other sites but I haven't gotten any clear answer of what I'm Supposed to do to fix this problem. Please help it currently my only transportation and I work 8 miles from home.
Post by jct842 on Mar 21, 2017 21:33:59 GMT -6
What have you checkled so far? Plug....air filter...hoses? Extra air getting in thru a loose or cracked manifold or a vacuum leak? Have even seen a couple here that had a carb get loose.
Almost forgot the most important thing .....have you checkled valve clearance? The valves especially exhaust closes up with use and those valves do need to be adjusted from time to time.
Post by cyborg on Mar 22, 2017 18:03:56 GMT -6
Pull the carb give it a good cleaning,,, sounds like clogged up jets to me
