Post by joshuah459 on Aug 7, 2017 22:10:25 GMT -6
I recently bought a old roketa bali 250. Its a diamond in the rough for sure and i need some help to repair it. Firstly it doesnt idle, just dies. You have to hold the throttle to keep it running. Second the previous owners bypassed the factory cooling system and installed a switch for the fan. How can I change that back to factory? Should I? Thirdly, I'm used to a 150cc gy6 motor, and have never worked on a 250 before. Are there any tricks I should know about? common issues? How often should the oil be changed on these? Stuff like that. Thanks in advance!!
Post by cyborg on Aug 12, 2017 20:13:12 GMT -6
Idle problem is probably a dirty carb,,, gummed up with varnish,,, give it a good cleaning and that'll clear up the idle issue
