Post by twowheeler on Mar 28, 2014 15:42:16 GMT -6
Post by Alleyoop on Mar 28, 2014 16:01:01 GMT -6
Question WHY do you want to block the ENRICHER? That only feeds fuel for cold starts. Do it right, if you want to control when you want or not want extra fuel put in a MANUAL one. Then if you ever get a new carb just take the ENRICHER off and slap in the manual, two little screws. Alleyoop
11,000 Miles and Counting...
Post by bhinch on Mar 28, 2014 16:10:27 GMT -6
I installed a manual choke from the forums and it has worked great for over 5 yrs. Try it...
Post by Deleted on Mar 28, 2014 16:19:51 GMT -6
yeah I wouldn't go blocking the enricher. just get a manual one like the other guys said and that should be good. I know the JB weld is cheaper but the other way is the right way
Post by cyborg on Mar 28, 2014 16:38:03 GMT -6
Yes I agree even here in socal I need to choke for the am run to work,,, I would love to have a two step one like the one I have on my dr,,,,,
Post by LUKE on Mar 28, 2014 16:47:05 GMT -6
just goes to show that you dont know anything about fixing scooters. blocking a choke? jizz!! redrush, you should be rushed to the mental hospital hahaha, just teasin you bro! plus, nobody uses jb wled anymore because its too thin an difficult to mold and takes time to harden. here is what i use
Post by kz1000st on Mar 28, 2014 17:17:34 GMT -6
JB Weld Quik hardens in minutes and JB Weld also makes an epoxy putty like Quik Steel. These are things you know when you own a Chinese scooter and miss when you trailer your scooter. Not to mention the exciting uses for Crazy Glue. LOL
Post by twowheeler on Mar 28, 2014 17:43:22 GMT -6
In fla I can get by. Do i just fill the entire hole all the way from the bottom to the top?
Post by Alleyoop on Mar 28, 2014 18:23:32 GMT -6
If your going to do it YES, even the area where the needle drops into all the way to the top. Alleyoop
Post by twowheeler on Mar 28, 2014 19:55:22 GMT -6
I was thinking abot snipping off the needle part of the enricher, placing in down in the hole they using the putty around and on top. Will that work?
Post by jvino on Mar 28, 2014 19:57:34 GMT -6
Yeah fill up with jb weld and put a piece of cardboard on top for flat surface. I am not exactly sure why you would want to do this I heard it is the enricher in some ones post which means it gives gas to engine when cold. I would think about not doing that due to this is how the carb is designed but I could be wrong. Sorry I don't understand why you would do that it is beyond me?
Good luck though.
Post by Deleted on Mar 28, 2014 20:20:25 GMT -6
he is in florida so probably not needed most times but there may be that one time that he'll need it and he wont have it. not a good idea IMO but its up to him. maybe concerned with it malfunctioning and staying open. using more gas when cold? if he ever sells it, the person that buys it will be going .
Post by jvino on Mar 28, 2014 20:23:52 GMT -6
Yeah if I took something apart like that I would be very confused?
Post by Alleyoop on Mar 28, 2014 20:24:35 GMT -6
Here are the Enricher holes that have to be blocked. Alleyoop
Post by jvino on Mar 28, 2014 20:27:11 GMT -6
Mabye plugging it with a piece of wine cork might work and also would be able to remove it if it didn't work and wouldn't destroy the part if it don't work right. This one has me confused trying to come up with some creative ideas that's all/ good luck though.
