Post by mxmatt on Apr 29, 2014 10:55:12 GMT -6
Oil Seals: Which way do I install them? Which side faces the case and which side is exposed?
Starter Clutch Locking Nut: Torque recommendation (what if I don't have job specific tool?) and can/should I use Loctite?
Post by twowheeler on Apr 29, 2014 10:59:21 GMT -6
You can use blue locktite on any part of the scoot.
Triangular Shaped Head!!
Post by FACE PLANT FOR LIFE on Apr 29, 2014 11:11:51 GMT -6
For extra effect, find a way to apply loctite to your steering column and then wonder why you can't turn anymore!
I'm joking, of course.
Post by Deleted on Apr 29, 2014 12:10:12 GMT -6
to answer your first ?: the side with the spring faces into the engine.
Post by cyborg on Apr 29, 2014 17:42:58 GMT -6
Smooth side out
Post by mxmatt on Apr 29, 2014 21:44:42 GMT -6
Lanternscooter and cyborg. Is the spring side and the smooth side the same side?
Also, I know that I should know this, but what is the torque spec for the starter clutch locking nut in Inch Pounds? I can never figure out Nm.
Post by Alleyoop on Apr 29, 2014 22:21:14 GMT -6
Here are torque specs for different size nuts. Alleyoop
