Post by mrgibbles on Sept 16, 2014 15:52:43 GMT -6
first picture is of cdi starter relay new spark plug nd spark plug wire 2nd pictures is the wiring behind where my killswitch and gauges is at front of bike
Last Edit: Sept 16, 2014 15:55:22 GMT -6 by mrgibbles
Post by mrgibbles on Sept 16, 2014 15:04:51 GMT -6
ok so now have new spark plug new cdi new spark plug wire new starter relay still wont start tryed testing for spark still no spark maybe im testing it wrong but im not seeing a spark
Last Edit: Sept 16, 2014 15:18:42 GMT -6 by mrgibbles
i tryed the remove fuel hose from carb put into cup and try to start and fuel did squirt out so my next step i guess is to check for spark even though i just got new spark plug ignition coil and starter relay a week ago if i test it and do have spark whats my next step?
Post by mrgibbles on Sept 15, 2014 19:26:21 GMT -6
i tried starting it with out gas cap same thing and there was still gas in it i just went to top it off i will try cranking it and see if gas comes out tomorrow need to charge battery from trying to start it to much so if fuel dosent come out then its my petcock?
Post by mrgibbles on Sept 15, 2014 19:11:12 GMT -6
ok so i went to gas station and filled up tank went to leave scooter wont start it sounds like its trying to start but dosent i can even here it move as it tries to start had to push scooter home from gas station what could be causing this? im thinking maybe fuel problem i have recently replaced ignition coil spark plug and starter relay how do i check and see if its getting gas?
Last Edit: Sept 15, 2014 19:13:58 GMT -6 by mrgibbles
Checked my oil it was little high drained some out with a straw seems that fixed the idle incase anyo e else had same problem that could be why also getting better top speed again now also seems was to much pressure because of the oil level glad I checke and for top speed I backed off at 68 could have gone faster but kinda squirrel y on those little tires past 70
Last Edit: Sept 10, 2014 10:02:26 GMT -6 by mrgibbles
from what i read he said the front break was damaged if he ment the part you pull for break then it could be his break sensor because wont start unsless break is pulled could just be a loose wire there
had a similar problem with my scooter turns out it was a break sensor and fuse that came loose have you checked your kill switch and break sensors also on some scooters kickstand must be up to start do your gauges come on when you turn key and have you check the inline fuse from battery to starter mine was right next to battery another thing it could be is your starter relay may be in backwards are you sure you put it in the same way it came out and the ingnition coil the wire that goes to spark plug should be green to green black to black in case its not on right also
just wanted to add i have a jonway scooter and from what ive seen it should be .005 inches for the valve gap if they are to tight it will have difficulty starting and running i would check your manual before adjusting them just to be safe
well what i use that seems to work well when its wet i got from amazon for super cheap i replaced my stock tires with these and the improvement was huge and considering the prices at motorcycle shops was twice what i paid for these i think it was well worth it
not sure if this is a problem but when i first start my scooter it idles at around 1200 rpm but after i drive around it warms up it idles at around 1900 it should be at 1900 idle just curious why it would be low when it is first started
