Jonway yy250tt
by: scootingalong - Feb 7, 2015 0:17:14 GMT -6
via mobile
Post by scootingalong on Feb 7, 2015 0:17:14 GMT -6
You got it, the old glass tube style, went with the blade type.
Jonway yy250tt
by: scootingalong - Feb 6, 2015 17:47:15 GMT -6
via mobile
Post by scootingalong on Feb 6, 2015 17:47:15 GMT -6
Fixed it, bad fuse link in the ignition wire between the key and the battery. Thanks for all the tips.
Jonway yy250tt
by: scootingalong - Feb 4, 2015 20:17:54 GMT -6
via mobile
Post by scootingalong on Feb 4, 2015 20:17:54 GMT -6
Thanks for the thought, I'll check it out too.
Jonway yy250tt
by: scootingalong - Feb 4, 2015 19:09:44 GMT -6
via mobile
Post by scootingalong on Feb 4, 2015 19:09:44 GMT -6
Thanks for the tip
Jonway yy250tt
by: scootingalong - Feb 4, 2015 17:40:25 GMT -6
via mobile
Post by scootingalong on Feb 4, 2015 17:40:25 GMT -6
Fuses are good, no resistance on the volt meter. I did discover that the most forward fuse in the fuse block, yellow/brown wires, have about 1 ohm resistance?
Jonway yy250tt
by: scootingalong - Feb 4, 2015 17:30:01 GMT -6
via mobile
Post by scootingalong on Feb 4, 2015 17:30:01 GMT -6
Thanks for the info I'll try the in line fuses
Jonway yy250tt
by: scootingalong - Feb 4, 2015 16:48:25 GMT -6
via mobile
Post by scootingalong on Feb 4, 2015 16:48:25 GMT -6
No power at all when I turn on the key. I can jump the starter solenoid and it's starts up? I have lights and signals when it's running. Turn it off and nothing? Checked the fuses, all good. I replaced the starter solenoid, Same thing, it didn't fix the issue. Any suggestions?
