Post by jeffintampa on Jul 16, 2016 11:17:40 GMT -6
Rosie didn't want to run today don't think I have all the bugs worked out. What to start with?
Post by jeffintampa on Jan 31, 2016 14:39:43 GMT -6
Well, It runs and seems to idle great. Fires up on the first kick or second, the Carb not quite tuned in I guess the scooter wants to die out as you throttle it bllllllaaaa back it back down and idles
Post by jeffintampa on Jan 31, 2016 14:00:46 GMT -6
Ok, figured it out was the CDI bought a used original one off ebay. Fired right up.
Now I am working on the headlight.... I don't think the bulb is good as I have power on the white wire blue and green are hooked up didn't light up.
The blue wire on this headlight has a splitter to the little light on the top of the bucket. I looked on ebay and didn't see the exact one. Can someone post the correct headlamp and were to buy it
Post by jeffintampa on Jan 30, 2016 5:22:04 GMT -6
Well back on the job, I bought a stock CDI not the new and improved one. I have nice power coming from the stater and indeed the new cdi did light up, but no power coming out of the yellow so we will see what the stock cdi does.
can I put a 12v battery in? what will that do?
Post by jeffintampa on Nov 15, 2015 17:49:39 GMT -6
Man I still cant get this thing figured out I have no idea why I don't have spark. Everything seems to be wired correctly
Post by jeffintampa on Nov 6, 2015 18:42:13 GMT -6
Post by jeffintampa on Oct 29, 2015 16:11:35 GMT -6
Hmm, I have flashing power to the coil on the Black with Yellow. But no spark.
Post by jeffintampa on Oct 29, 2015 15:44:53 GMT -6
New cdi clip is right CDI harness yellow - black yellow red - black red strip black - black white strip green - green blue - Blue with yellow strip
Post by jeffintampa on Oct 29, 2015 15:40:42 GMT -6
Well, I was able to remove all the wires and move them into the proper places Green to green red to red loop 2 Black and red
Have power at top of connection
still no spark Horn honks but tail light didn't come on
what now.......
Post by jeffintampa on Oct 29, 2015 14:55:35 GMT -6
Ok man what a screw up.....The new batter came with a new plug to match the harness, it had a new loop wire everything plug concave to fit one way and guess what (didn't really check it clicked perfect)
Battery Red into fuse to green Blue into Black with a red strip Loop into Red, and Black with a red strip
Aint that a kick in the head.
will post a picture later (wife has camera) going to rewire and let you know what happens
Post by jeffintampa on Oct 25, 2015 16:34:17 GMT -6
Post by jeffintampa on Oct 24, 2015 20:39:47 GMT -6
were I am at
Post by jeffintampa on Oct 24, 2015 20:38:04 GMT -6
in process
Post by jeffintampa on Oct 24, 2015 20:36:11 GMT -6
Here she is
Post by jeffintampa on Oct 24, 2015 17:58:58 GMT -6
Alley thank you so much first off for your help. I seems that ground on the intake was the original location as it was there when I started the rebuild. I can find someware else but does it have to be to the engine? Were is the Stator you talked about located on the bike for the next thing to try. I checked the fuse its good, battery has a small spark when neg and pos touch for a sec.
