Post by realicya on Jul 7, 2018 8:17:14 GMT -6
I have everything running again!!! Except now it just takes longer than normal to start
Post by realicya on Jul 6, 2018 15:21:22 GMT -6
I took the air filter boot off since my moped will run with or without it and before I put it back on I left it off until I on I the carb and everything is fixed and gas was leaking out of where the boot connects
Post by realicya on Jul 6, 2018 9:36:57 GMT -6
It's leaking on backside where the air filter plugs up,guessing it would be my float needing adjusting?
Post by realicya on Jul 6, 2018 9:31:25 GMT -6
How do I check the float needle that's one thing I havnt done
Post by realicya on Jul 5, 2018 19:10:45 GMT -6
Carb is starting to leak now and I can't find where
Post by realicya on Jul 5, 2018 6:46:18 GMT -6
Cleaned the main jet along with the rest of carb again,still acting up,all my hoses are good too so no vac leaks,what else should I check for?
Post by realicya on Jul 4, 2018 10:55:11 GMT -6
Ima check the filter first
Post by realicya on Jul 4, 2018 7:55:11 GMT -6
Just had a brand new carb put on and valves adjusted since I've had this issue before and the moped ran fine until yesterday I pulled the wire off my spark plug to change it and didn't have the right socket so I drove up to get one and came home and it started to bog out on me!!! What can be the problem and why does this keep happening?
