Post by superdavegulvak on Jul 30, 2012 11:52:40 GMT -6
Got all the body panels back on & battery on charger to replenish all the starts & no riding. Gonna start riding it again to see if it drains battery dead & how long it takes. Creature of habit in my 2 mile bubble. Hope to see if it always dies at same amount of run time or if it is intermittent & loose wire I haven't found. If you need to jump a scooter as long as car isn't running & you take cables off after it starts you shouldn't damage anything correct?
Post by superdavegulvak on Jul 30, 2012 11:45:56 GMT -6
Equal across all 3 wires
Post by superdavegulvak on Jul 30, 2012 9:42:22 GMT -6
Well I got 18 at idle & mid 90 on acceleration.
Post by superdavegulvak on Jul 30, 2012 5:18:29 GMT -6
Cool thanks Rich! After I get done with the mountain of dishes this morning I'm going to test the stator Will let you know how things turn out.
Post by superdavegulvak on Jul 29, 2012 10:39:29 GMT -6
Ok so all 3 wires coming of the stator are black so no idea how to test that but did notice the wires in back of plug were loose so I pushed them in good. Now I get 12.8/9 at idle & 13+v on throttle but only with the headlight off? Idle volts drop to about 12.3 & about 12.9 on throttle when headlight is on. Gonna try to get a video so you guys can see the multimeter later today. So you think there is a bad ground on headlight or some kind of a short? Or does this make sense if the rectifier regulator goes bad & can't handle a load being put on it?
