Post by chuck01 on Apr 23, 2014 8:42:11 GMT -6
Thank you! This will help greatly.
Post by chuck01 on Apr 22, 2014 10:40:42 GMT -6
I found the problem with my not idling, replaced the carb.. Now this unit runs fine except when you let off the throttle, then unit stalls out. I've been reading about adjusting the fuel mix on my 50cc 4t, but there's no adjustment screw!! WHAT??
Post by chuck01 on Apr 11, 2014 13:19:57 GMT -6
Yeah, the carb looks like that one. I have two vacuum lines coming from the curved black piece that the carb. connects to. The one goes from the intake manifold to the fuel valve, the other is coming from the intake manifold and is going to nothing, it is plugged with a bolt. At this point I'm looking for a carb. or a rebuild kit.
Post by chuck01 on Apr 10, 2014 13:06:53 GMT -6
4t. don't know history, came to me in this shape.
Post by chuck01 on Apr 10, 2014 12:21:30 GMT -6
I took the carb. apart and cleaned it. This carb. has no adjustment valves for the pilot valve. I thought the pilot was clogged but it isn't. Are there any vacuum schematics for these engines, cause I have a vacuum line but nowhere to connect it. I don't think it has the right carb. on it.
Post by chuck01 on Apr 10, 2014 11:58:38 GMT -6
I'm working on a 2011 50cc, that will start and run for @40 seconds, and then slowly idle down and shut off. It won't continue running even at throttle.
HELP
