Post by sarah on Jun 5, 2014 9:34:19 GMT -6
Help! I had a "friend" take out the carb in my Jonway, and left it. I need a manual, video, or map that will show me where all the fuel/vac lines go back. I have looked everywhere! Please and thanks!
Post by Alleyoop on Jun 5, 2014 14:00:45 GMT -6
If you need more help than the 2 pictures take a picture of your carb and hoses and I will label your pictures of your carb and hoses and tell you where each one goes to. Alleyoop
Post by Bashan on Jun 5, 2014 15:07:08 GMT -6
Did you look in the Library under "air, fuel, and carb" ? This tutorial might help. There's lots more where that comes from.
Post by sarah on Jun 9, 2014 14:03:18 GMT -6
Thanks so much!!! I've got it running! I am still having trouble with the idle. It will not start or idle with out giving it a little gas. I have adjusted the air/fuel ratio valve (clockwise until it stops then 2 1/2 turns counter clockwise until the ramp is at its high point). Is there anything else I can do, or look at to fix this? 4ever greatful!! Sarah
Post by Alleyoop on Jun 9, 2014 15:18:51 GMT -6
It may be idling to low, see the IDLE SPEED SCREW in the 2nd picture TURN THAT CLOCKWISE about 1/32 or so does not take much to bring up the IDLE. That by the way is as if you where giving it a little gas DOES THE SAME THING. Alleyoop
Post by sarah on Jun 9, 2014 17:27:36 GMT -6
Thanks Alleyoop!!!That did the trick. You just made for one great summer!!
Post by Alleyoop on Jun 9, 2014 17:37:57 GMT -6
FANTASTIC!! Easy a pie fix. Ride Safe Alleyoop
Post by sarah on Jun 25, 2014 9:21:18 GMT -6
Hi! I have one more question...I think...Where does the fresh air hose from the pair system go? I don't have that part, just a hose end dangling in the wind.
Post by Bashan on Jun 25, 2014 10:34:09 GMT -6
That's what it does, it just dangles in the wind. It is simply an air intake and doesn't hook onto anything.
