Post by tember1214 on May 30, 2014 16:12:22 GMT -6
Just cleaned carb a few weeks ago. I'll clean it up again and see if that works.
Sent from my XT1058 using Tapatalk
Post by Alleyoop on May 30, 2014 18:08:38 GMT -6
Ok, now we are getting somewhere, did you put on a free flow exhaust or did you get a new carb or anything at all? How bad does it bog really bad or just a little? Also is your carbs Fuel Ratio Mixture screw plugged or available like this: Alleyoop
Post by tember1214 on May 30, 2014 19:58:42 GMT -6
No free flow exhaust. Bought it on craigslist and carb looks new. It bogs most of the time at full throttle and then it acts like it catches up with itself (if that makes any sense). Sometimes it's worse than others. Some people have suggested up jetting. Also I don't see any vacuum line directly on carb. I have one straight from petcock and connects right behind carb. I'll upload a pic tomorrow
Post by Alleyoop on May 30, 2014 20:23:02 GMT -6
Does your carb have an ACV valve on the right side like this? If so you need a Vacuum line going to it. Alleyoop
Post by tember1214 on May 31, 2014 4:06:54 GMT -6
It does not. Should I be getting a carb that does?
Post by tember1214 on May 31, 2014 4:33:13 GMT -6
mine looks like this
Post by Alleyoop on May 31, 2014 12:11:09 GMT -6
No that carb is fine, that is what usually come on 50cc motors. On the other side of the carb you should see the fuel ratio mixture screw turn it Counter Clockwise 1/2 turn and see if that helps the bog at wot. Alleyoop
Post by tember1214 on May 31, 2014 14:24:52 GMT -6
Yeah I've done all that adjusted the carb every which way. Gonna clean carb and see what size jet I have and if it's for some reason clogged again!
Sent from my Moto X
Post by tember1214 on May 31, 2014 14:25:19 GMT -6
I don't know what else to do. I've literally gone through everything
Sent from my Moto X
Post by Alleyoop on May 31, 2014 14:49:57 GMT -6
OK LETS FIND OUT what it needs at WIDE OPEN THROTTLE:
Take it up to SPEED and WHEN IT ACTS UP BACK OFF THE THROTTLE A LITTLE about 1/8 to 1/4 of an INCH AND HOLD IT THERE. NOW PAY ATTENTION to what the motor does. a. DOES IT SPEED UP? b. DOES IT JUST SETTLES DOWN and runs good there? Alleyoop
Post by tember1214 on May 31, 2014 15:25:48 GMT -6
Speeds up
Sent from my Moto X
Post by Alleyoop on May 31, 2014 15:52:45 GMT -6
GREAT!! it is LEAN needs more FUEL get the next bigger main jet Don't go overboard just the NEXT BIGGER MAIN JET otherwise it will bog with to much fuel. Alleyoop
Post by tember1214 on May 31, 2014 16:07:49 GMT -6
Awesome hopefully that fixes it. Gonna take it apart and order the jet
Sent from my Moto X
Post by tember1214 on Jun 1, 2014 15:36:36 GMT -6
Fixed my problem!! Cleaned carb again and adjusted the diaphragm needle and put the clip all the way down. NO BOG at all!!! Running better than ever and even has better/faster acceleration!! Don't think I even need to up jet. At this point it's running great so I'm not messing with it haha
Sent from my Moto X
Post by Bashan on Jun 1, 2014 15:57:44 GMT -6
When you put the clip down you raised the needle up. That pulls the needle out of the jet more and does what Alley suggested which is get more fuel in. That is what the larger jet would have done. The larger jet is technically the fix for these problems but Alley would tell you just as I would, if you think it's running well, don't mess with it. You might open a can of worms and make things worse.
