Post by tember1214 on Jun 11, 2014 17:25:49 GMT -6
So my brother bought this and had to replace gas tank, I went to put it on today and there is a hose coming from top of tank. The only explanation I can find is that the gas tank he got was from a California model. So my question is since there is no place to connect the hose can he still use the tank?
Sent from my Moto X
Post by rks on Jun 11, 2014 17:58:45 GMT -6
I don't have a Honda, but my fuel tank has two lines or hoses coming out of the top of it. One is the feed to the fuel pump, and the other is a vent line. The gas cap is not vented, so the only way to get air into the tank to replace the gas being drawn out, is through this line. So if it is a vent, just place a cheap gas filter on the end, (just to keep crap out) and zip tie it somewhere high on the frame....Bob
Post by tember1214 on Jun 25, 2014 11:38:30 GMT -6
OK so after about a month of switching parts and fixing things finally got my brothers ch80 running!! One issue is we adjusted the valves 3 times and they knock soooo loud when driving!! Runs and rides fine. Any ideas? ![???](//storage.proboards.com/3059616/images/uQfospbezE7IcMUG1AtY.gif) ?
Post by Bashan on Jun 25, 2014 14:07:10 GMT -6
No, that is too noisy. What did you set them at? The cold clearance on that engine is .05mm or .002".
Post by tember1214 on Jun 25, 2014 18:22:24 GMT -6
Yes we set them to .002"!! Not sure what the issue is.
Post by cyborg on Jun 25, 2014 18:30:57 GMT -6
you sure you were at top dead center?,and cold like over nite don't start it till after your done cold?
Post by tember1214 on Jun 25, 2014 18:43:25 GMT -6
Yes definitely cold and I'm 99% sure it was top dead center. The flywheel is very rusted can't see any markings. I had what I think is the timing marks lined up though
Post by Alleyoop on Jun 25, 2014 19:21:02 GMT -6
if your not sure due to the rusty flywheel, take the plug out and stick a straw down there and rotate the motor with your hand turning the flywheel CLOCKWISE and watch the straw it will go up and down. So turn it so the straw comes out the furthest that will mean the piston is all the way to the top. Now you should be able to grab the rockers and wiggle them with your fingers(BOTH OF THEM. Or if you cam SPROCKET looks like this line it up like in this picture and forget about the timing marks on the flywheel. Alleyoop ![](http://i59.tinypic.com/j802zp.jpg)
Post by tember1214 on Jun 25, 2014 19:58:50 GMT -6
Thanks will try the straw trick!
Post by cyborg on Jun 25, 2014 20:02:31 GMT -6
make sure it's after the intake valve closes
Post by Bashan on Jun 25, 2014 20:11:46 GMT -6
Here's some alternative valve setting methods that Alley hates. Rich
