Post by stellarfoxy on Jan 10, 2015 13:19:49 GMT -6
hello everyone! I've been using the information here for awhile but I've run into a wall, I've tried searching and tried everything suggested I've found thus far, to no avail.
first some history: about 6 months to a year ago, I acquired what I find out was a taotao power max 150cc that had been left in an abandoned heap behind a shed of a friends rental property. 85% of it was there, but it was missing a few key components, most importantly the entire ignition, intake and exhaust. having no experience with small engines or carburetors whatsoever, I set to work. I purchased an (allegedly) 26mm carb, uni filter, high end fuel and vacuum hoses, orange coil, correct ngk plug, both manifolds, battery, slant tip "performance" muffler, orange adjustable cdi, etc. in intervals. after installing just the coil/plug/stock cdi/intake without filter, it started, ran, revved, everything! so I installed the filter and exhaust. a couple weeks later I got/installed the exhaust and air filter and it gradually became much harder to start and keep running. I figured I'd stripped the plug hole so I tapped it to a 12mm- still hard start but it ran then died after a few minutes. checked compression, it was 150psi at full throttle. I adjusted the valves to .004/.005mm using the method where I do one valve at while the other is compressed. while I was in there, I decided to check timing, it was incorrect- when the cam holes were aligned, the casting mark was in the box after the "t" line. I moved the chain up a link and it sat on the "f" mark. it would crank and run like this but die after a couple minutes. set the chain back and it was even harder to start. I checked the tensioner (vary carefully!) and later replaced the chain which was difficult without removing anything but valve cover, yet the marks were the same (notes: woodruff key is in place and "t" mark lines up with cylinder at tdc, holding plug to valve cover always gives spark).
today I replaced the carburetor with another new one hoping I'd got a bum carb before or it was failing or whatever. it finally started after spraying starter fluid in one of the vacuum lines! I kept it running for about 20 minutes, it would rev and come back to idle perfectly (some backfiring but I'll deal with that once it's more solid). it seemed to run best with the timing dial on the cdi set back (less advance I assume?). I noticed that it also wanted to die with the enrichment circuit plugged in, but unplugging it kept everything happy and smooth. so I killed it using the switch and went to start it back up, with absolutely no success.
I'm wondering if I need a bigger idle jet, or to adjust the idle screw on the carburetor? it's currently at 2 turns out. also, after much deliberation about the timing issue, I assume the only reason it can be off like it is, is if the gear on the crank slipped, is that possible? I have no idea the history of this engine, any input is welcome. I think I covered everything but if not I will tell you whatever I know!
hope I'm not violating any rules and this isn't in the wrong area, lmk if I need to change anything.
