Doc's Anything Goes
Say no to scooter abuse
Post by jct842 on Jun 4, 2017 10:28:03 GMT -6
Learning to use that meter is part of riding chinese. If it's too much buy A JAP SCOOTER. a CHINESE SCOOTER WILLL RIDE JUST AS GOOD AS YOU do a bit more maintainance.
Doc's Anything Goes
Post by jct842 on Jun 2, 2017 20:18:07 GMT -6
To find air or vacuum leaks .....run at around idle...mist water...ether...carb Cleaner or what ever all over arb manifold area. You are looking only for a speed change up or down..don't matter .....speed change is a leak
Doc's Anything Goes
Post by jct842 on Jun 2, 2017 20:09:01 GMT -6
Why not reveil what scooter you bave, unless you want to keep your problem to yourself
Doc's Anything Goes
2018 sx650
by: jct842 - May 26, 2017 13:30:43 GMT -6
Post by jct842 on May 26, 2017 13:30:43 GMT -6
Just the one I was looking for, and for a long long time. Too late now though. A real motorcycle. Non of that transformer look... why the hell didn't the keep making it, I definatly would have have one a few years back. I would post a pic but am on tablet and not that smart. I have an expensive Samsung 10" 3 years old and it is a piece of crap and now the battery is taking a crap.
Doc's Anything Goes
Post by jct842 on May 22, 2017 12:45:49 GMT -6
Good reasons to not run wide open!
Doc's Anything Goes
Post by jct842 on May 21, 2017 11:47:44 GMT -6
spacer? or get the right one.
Doc's Anything Goes
Post by jct842 on May 20, 2017 15:31:58 GMT -6
You will kill your engine. A gy6 is a fan cooled engine and needs every bit of air that little fan can make.
Doc's Anything Goes
Vibration
by: jct842 - May 18, 2017 19:39:45 GMT -6
Post by jct842 on May 18, 2017 19:39:45 GMT -6
And a straight up 90 degree engine should last longer being better balanced. The weight of the yami clone piston sliding along the flat cyl surface is the killer.
Doc's Anything Goes
Vibration
by: jct842 - May 18, 2017 19:39:20 GMT -6
Post by jct842 on May 18, 2017 19:39:20 GMT -6
Doc's Anything Goes
Post by jct842 on May 18, 2017 19:31:57 GMT -6
I would do a little math when switching bulbs. Take the total oem watts or curent draw and stay under it and you will find the leds are much brighter for the same curent draw. Less curent leaves higher working voltage.
Doc's Anything Goes
GY6 Info
by: jct842 - May 18, 2017 19:21:22 GMT -6
Post by jct842 on May 18, 2017 19:21:22 GMT -6
It all depends on the state. I know that there are a few 50cc and 150cc that are almost identical. In their cases I know of some who carefully remove the 150 leters and replace with 50cc decals or raised letters which are readily available. As long as you keep speeds in the 50 range and the law is lenient you might be ok. BUT DON'T BLAME ME IF........
Doc's Anything Goes
Post by jct842 on May 17, 2017 21:54:37 GMT -6
I think I would be looking for an led you could replace it with of the same wattage as the original. Using that machine at night is a real ify thing. Going above the wattage can lead to problems, adding leds to tail could free up amps. The low watts of original does not give much light to start with. A led is much brighter for same watts.
Doc's Anything Goes
Post by jct842 on May 15, 2017 15:48:40 GMT -6
Engine number normally near kickstand lower left
Doc's Anything Goes
Post by jct842 on May 10, 2017 20:53:53 GMT -6
You did good. Spending a lot of money on some thing old is nuts unless you have a cherry and expect a good return on completing a restoration. In the case of cars people restore and pay to restore and then find they could have bought one just as nice for a lot less.
Doc's Anything Goes
Post by jct842 on May 10, 2017 20:48:26 GMT -6
The larger jap. scooters are way over priced and when they list touring they make an oxymoron out of touring. and if you are over 6 ft you are squashed riding them. Their shocks are poor compared to a motorcycle in the same price range. A scooter is best around town. A grocery getter. You can also tour on a 50cc if thats your thing but I think comfort.
