Post by mike932 on Feb 8, 2015 14:15:57 GMT -6
Ride scooter today for two hours. It performed beautifully. Thank you everyone for your help.
Post by cyborg on Feb 8, 2015 14:48:12 GMT -6
I love it when a plan comes together,,,,
Post by Alleyoop on Feb 8, 2015 15:02:27 GMT -6
Post by mike932 on Feb 14, 2015 14:20:23 GMT -6
Update: Scooter is working fine, but I woke up this morning and hooked up mulitmeter to battery and is reads only 12.36 volts. Should I be concerned? I have ridden the scooter every single day since I replaced the battery.
Post by Alleyoop on Feb 14, 2015 14:40:59 GMT -6
If it is cold out overnight batteries do loose some amps. So here is what I would do to verify that your Scooters Charging system is working. Test to see if when running the battery is being charged up if it is and the battery does not drop below 12v overnight when really cold temps then your fine. But if it drops below 12v overnight after you were riding for at least 30 minutes then I would suspect the battery is most likely dieing a slow death one of the cells is not doing its job. Alleyoop
