Post by mike932 on Feb 6, 2015 17:44:58 GMT -6
I removed the battery in order to take it to get tested, so I will eventually reconnect it carefully. It did have some kind of brown grease on the terminals. Does that matter?
With the scooter battery removed, I will connect a jumper cable from the positive terminal of the battery inside my car to the positive terminal connector in the scooter. I will then connect the other jumper cable from the negative terminal of the battery inside my car to a non-fuel piece of metal inside the scooter. I will then try to start the scooter with the car engine off.
Actually, I could connect the negative cable to the negative terminal connector in the scooter since there is no battery inside the scooter which could explode.
Administrator
Post by JR on Feb 6, 2015 18:07:57 GMT -6
Battery will be fine if you leave it in and hooked up, put the jumper cables on properly but do not start the vehicle you hook up to then start the scooter. You also need to put your volt meter on the battery and take a reading with it at idle, then rev it up and see if the voltage increases. You can do all of this with a car battery hooked up and the scooter battery also.
JR
Post by mike932 on Feb 6, 2015 18:15:32 GMT -6
Already done. Hooked up car battery without scooter battery in scooter. Scooter lights work great. Scooter started easily. Turned off scooter engine. Started scooter again easily. Repeated 5 times. Scooter started easily 5 times, so it must be either bad scooter battery or bad battery terminal connection, right?
Now I inserted the questionable scooter battery back into scooter. There was no snapping sound that usually happens when connecting a battery. Scooter lights did come on and scooter did not start. I then used multimeter to see that scooter battery only has 11.1 volts now, so 12.7 must had been just a surface charge as Alleyoop suggested. Time for new battery, right?
Administrator
Post by JR on Feb 6, 2015 18:27:00 GMT -6
Hard to say? Why? If it's a loose connection it'll not show it's face until you're riding the scooter and it jars loose?
So here are your choices IMO:
Trace the scooter battery cables and make sure they are tight and clean especially the ground (negative) cable
If you find nothing loose or corroded then put your battery back in, if it won't start/run buy a new battery and see if this cures it
If it starts/runs ok then give her a spin and see if it acts stupid again, if so then it's time to start hunting a electrical gremlin.
JR
Post by mike932 on Feb 6, 2015 18:30:12 GMT -6
I figure buying a new battery is never a bad idea anyway since they only last a few years, and the one I have is probably pretty old. JR, make sure you reread my prior post which I edited to say that my scooter battery has only 11.1 volts now.
Post by mike932 on Feb 6, 2015 18:50:33 GMT -6
My questionable scooter battery is an 8-amp Bike Master TruGel MG7C-A non-spillable. There is this number stamped on it: M0107DA6. Is that a date stamp?
Post by Alleyoop on Feb 6, 2015 19:23:38 GMT -6
Just get a new battery, as you experienced when you connected the car battery it started no problems whatsoever. And as you tested the voltage has now dropped even further. So when you turn the key on and hit the start button if you test it then I will bet it drops down into the 6 range which will give you nothing. Batteries are funny the surface charge may be good but as soon as you draw juice from it like a bulb it will light up zapping the surface voltage and then start to dim.
Post by mike932 on Feb 6, 2015 19:31:55 GMT -6
Looking for batteries online right now. Dimensions are: Product Width 3.54" Product Length 5.12" Product Height 4.49" Are the ones that must be filled by the customer any good?
Post by JoeyBee on Feb 6, 2015 19:46:10 GMT -6
Not sure what the stamp would be. At least we know you need a new battery. I'm guessing once you replace it you will be good to go.
Post by mike932 on Feb 6, 2015 19:52:00 GMT -6
The car battery was a good idea, eh?
Post by cyborg on Feb 6, 2015 20:22:23 GMT -6
I checked the date stamp you put up on the board and they transposed the letters the date of manufacture is 1070AD ,,,,  ,,,, go buy a battery alright already
Post by Alleyoop on Feb 6, 2015 20:30:13 GMT -6
GOOD ONE, MAN THAT IS AN OLD BATTERY
Post by cyborg on Feb 6, 2015 20:35:44 GMT -6
Yes mike good call on the battery,,,,when testing its nice to have a clean steady supply,,,,I'd still go thru the beast and check all terminations ,,,ground lug on frame engine ground ,,,everything,,,just for peace of mind,,,,and yes the manufacturers usually send the batteries "dry",,, with a gang bottle of the acid,,,the top of the battery cell openings have the piercing tool built in,,you just take out the caps insert gang bottle on top tap it in place and come back 10-15 min later and it's done,,,easy peasy baby
Post by mike932 on Feb 6, 2015 20:36:07 GMT -6
I suppose I should post a photo of my battery....
Post by cyborg on Feb 6, 2015 20:45:15 GMT -6
The same kind they used in Egypt,,,,,archeologists found shards in a trash heaps,,,,and they know this how?,,,,,,,,,, no carbon soot in the paintings,,,,bingo!!!!!! Tell him what he won Wink!!!!!!!!!!!!!
