Post by Deleted on Feb 23, 2015 13:18:39 GMT -6
recently picked up this 1926 De Laval 2 1/2hp engine which was made for the company by lauson. these were sold to run milking machines and cream separators but were used for just about everything. heres some pics, they were originally 16Mp and were taking forever to upload so i had the camera resize them to 640*480. this engine has had a head repair from freeze damage a long time ago. looks to be holding up well. heres a video: seems to run pretty good. missing a few original parts like the crank guard and gas tank. most you see are missing that though. the oiler isn't original, the right one is solid with just a hole to observe how many drops per minute you are getting. you would think it would be hard to start, but like the Cushman i got, it usually starts within 1-2 turns of the flywheel even in this single digit weather
Post by jct842 on Feb 23, 2015 13:46:58 GMT -6
I like
Post by cyborg on Feb 23, 2015 13:51:04 GMT -6
that is the coolest thing lantern
Post by richardv on Feb 23, 2015 16:27:05 GMT -6
Thanks for sharing. Do you operate equipment with them? Like at shows.
Post by cyborg on Feb 23, 2015 16:33:12 GMT -6
Hey lantern is that your red fox in your avatar?
Post by Deleted on Feb 23, 2015 18:13:03 GMT -6
Thanks for sharing. Do you operate equipment with them? Like at shows. Haven't got much to run with them, I see some people will run a squirrel cage blower with them if nothing else. Maybe I could do something like that.
Post by Deleted on Feb 23, 2015 18:14:49 GMT -6
Hey lantern is that your red fox in your avatar? No but I wish it was. That would be nice.
Post by cyborg on Feb 23, 2015 19:45:12 GMT -6
Time to find an old dynamo,,,, you can use it as an emergency generator for like no money
Post by Deleted on Feb 24, 2015 17:54:13 GMT -6
Time to find an old dynamo,,,, you can use it as an emergency generator for like no money Problem with that is the engine doesn't hold a consistent speed, maybe would be good for a 12v gen to charge a battery to run an inverter.
Post by cyborg on Feb 24, 2015 19:46:43 GMT -6
they do hold a consistant speed when they have a load,,,,,when they dont then they skip,,,,
Post by Deleted on Feb 24, 2015 20:00:23 GMT -6
they do hold a consistant speed when they have a load,,,,,when they dont then they skip,,,, they still waver around like 50-75 rpm's, which would mess with voltage and frequency output. we park near a guy with an Ottawa drag saw with an old tach attached to one crank end. it doesn't sound like it wavers much but its actually quite a bit. this ones maximum speed is 500 RPM so it would translate out to more RPMs at the gen because it would need to be geared up to run at either 1800 or 3600 RPM
Post by jct842 on Feb 24, 2015 21:31:01 GMT -6
Just checked ebay, wow them things cost a lot! A maytag may have been the straw that broke the camels back when it comes to my old bosses divorce 35 years ago. He bought one at a fair about a month before the coming divorce was made public! Could have been a girlfriend too, he bought one of them too!
Post by Deleted on Mar 25, 2015 16:26:49 GMT -6
Got another video of it after replacing the leaking oiler pipe and adding an elbow to the exhaust to keep soot off the side of the engines
Post by richardv on Mar 25, 2015 18:01:32 GMT -6
I have been told that sound can become addictive. What do you think?
Post by Deleted on Mar 25, 2015 20:00:27 GMT -6
I have been told that sound can become addictive. What do you think? Yes it can. I have that engine , 2 Cushman cubs and a maytag 92
